Cut might be out bounds neje max4
Hi, I need some advice.
I’m burning vector image. After 3 minutes I change the parameters of the laser. Then I get this warning. I don’t know how to get rid of it, I haven’t changed anything. If I load another image, this warning still appears.
I have set the parameters correctly.
Have you used the Jog tools in the Move window to set the origin for use?
The following may be of interest to you.
User Origin is described at 5:26
I see that your work area is wider than it is tall…
That strikes me as unusual but not impossible.
In the Console window in LightBurn, please type the following:
then press enter.
Select and copy that text and paste it into a reply here. The Machine settings report will help us confirm the orientation of your machine. :slight_smile:
$0=10
$1=255
$2=0
$3=0
$4=0
$5=0
$6=0
$10=3
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=250.000
$25=2500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$40=0.200
$41=10
$42=10
$43=0
$100=80.000
$101=80.000
$102=800.000
$103=8.889
$110=24000.000
$111=15000.000
$112=1200.000
$113=21600.000
$120=400.000
$121=250.000
$122=20.000
$123=250.000
$130=750.000
$131=460.000
$132=45.000
$133=360.000
the position of this device has such dimensions. I have a laser for a short time. I’m still learning from it. It worked well until today. I haven’t changed the settings. I don’t know what’s wrong. :pensive:
If I confirm yes, it will crash in these places.
Sorry to step in.
For a start select absolute coordinates.
Home the laser.
try again.
Read again and see video again.
