Cut might be out of bounds- Continue anyway Message
I position the laser in the home position.
I position my work piece in the home position.
I start from Current Position bottom Left.
And then Start.
I get the message that “Cut might be out of bounds”.
I does cut.
Beside this message I am also unable to Frame my work
Please help
The only time I get this is usually a stray line or something that is not set to output being outside the boundry.
CTRL A, to select everything usually shows if this is the case
