Cut on screen different size then the cutting on machine
When I draw a simple 20 x 20 mm square in lightburn and then send it to my Emblaser2, the laser makes it about 18 x 18 mm. I can not get the laser to cut the size shown on the screen. Been using software and laser for 3 years with no problems.
Older drawing I made also get cut out smaller then they should be, compared to the size on the screen. A week ago everything was fine, maybe I activated something I should not have…
Can’t find a solution.
Len de Vries, Netherlands
Check that you don’t have an inadvertent kerf offset configured in the Layer settings.
If that’s not the problem then please share a .lbrn file where this is occurring.
