Cut option on second cut
I am doing file where my first cut is on the inside, my second is on the outside.
I can only select cut on the inside, the outside I can do line or fill not cut. how do I change this?
thanks
Can you show screenshot of project with your cuts/layers window?
There is no “Cut” option in LightBurn, there is only Line and Fill.
“Line” mode is used for cutting and light marking, with the only difference being that you run slow with high power to cut, and run faster and/or lower power to mark.
if you notice on the red layer you can see cut
Cut is just the name of the layer. You can delete the name or name blue layer cut also.
