Cut order on designs
Hello, I designed a file in lightburn, it’s a pair of sunglasses with an intricate design in the middle. When I transfer the file to my glowforge to cut it, it cuts the outline of the sunglasses first, and the intricate designs after. Is there a way to have it do it the other way around (aside from using different colors)? I’m hoping this question is making sense!
How are you doing this? If you’re transferring this as SVG then cut order would be determined exclusively by the Glowforge software so you’d have to attempt to change this there.
Yes I am transferring it as an svg, thank you for your response! That makes sense and was what I suspected.
