Cut Origin on work
How do you reset the cut origin without losing your work?
It’s not considered kosher to make multiple post of the same question …
If this is a different question, I’m apologize… but clarify here what you are asking…
Sorry about that. How do you reset the origin where the software understands that is the starting point?
Lightburn has the ‘Start from’ selection … if you use ‘user origin’ you have to set the origin on the machines console when the head is where you want it.
If you set it for current position, it will go from where it is… and absolute coordinates matches up to the work area on the screen.
