Someone showed me how to get the laser to cut a path in the center of my lines in the drawing but I can do this again. I for got how I did this. I’ve been at it for hours. Thanks
desert horse 276 401 cinterline.lbrn2 (719.7 KB)
Do you want to cut the horse out? There are a lot of gaps in your lines.
I want it just like it is in the LB file. I just forgot how to do it. I have the image file and I want to know how I did the line layer.
For the most part, it looks like you did a pretty good job. You need to extend a few lines, and there are a few short lines that could be deleted.
Lightburn doesn’t offer center line tracing yet. You need to use a different tool. Inkscape has this function and there is a free online tool called rapid resizer that also does this. I’m sure there are others as well.
That’s it, I opened an Inkscape file with lightburn then saved the file in Lightburn and a year later I thought I made the path with Lightburn. I had the Inscape file right next to it!! Duhh
