Hello guys , a small problem, after the last update I lost some settings.
1- before the update my machine starts cutting the inner shapes then the outer,
2- when I put more shapes with different colours the machine is not following the colour I set up.
Any help please to get those 2 settings back
Thank you
You have likely changed your optimization settings. Make sure ‘Optimize Cut Path’ is enabled, and check your Optimization Settings as well. The default is this:
