This is happening when I want’ to cut small section.
https://youtu.be/70MZjMmfQ_A
This one I believe it´s better call @LightBurn.
Could you Post your project file .lbrn2?
This is file from which I started cuting.
ograja4.lbrn2 (17.7 KB)
Lightburn Version 1.7.03 or lower?
I can replicate this.
Your design has 111 duplicates maybe that´s the culprit.
Trimmed all the shapes but 2, during the operation the same happened but I Ctrl + Z trim a few shapes them trimmed the offending one.
When I trim those two consistently the left and the right square goes away.
You can get ride of them with Node edit.
ograja4_edited.lbrn2 (32.9 KB)
You have to select all the shapes and to Break Apart first.
Ctrl + A, Alt + B, Alt + D.
