The cut height is more than double of what I select in lightburn. It doesn’t matter if I import the file or create it in lightburn. The cut width is accurate.
Did you try Edit>Machines Settings>Calibrate Axis?
If you have not, and your measurement seems so far off, start with a small square, like 50mm. If it gets closer to correct, then you should do a larger square to get the best accuracy.
