Cuts and Layers - Pass Count
With Pass Count set to 1, the machine still does 3. How to make it do only 1.
Probably best to post a lbrn2 file that exhibits this behaviour for review
Does it do this in the preview?
It is the best way to determine what the machine is going to do… save time/money and materials…
If you go to the EDIT menu there is an option to delete duplicates. Ungroup the job and select the parts that are duplicating, then click on the EDIT menu and select “delete duplicates”. You will get a popup that will tell you if there are any duplicates and will give you the option of deleting them.
