When you select an object in the workspace it gets highlighted in the Cuts/Layers panel.
Conversely,
It would be nice if when you selected the layer in the Cuts/Layers panel that it would select the object in the workspace.
Yes/No?
If you hold shift and click the layer it will select everything on that layer.
Thank you!
Obviously, there’s more document reading necessary on my part.
You can also use Edit > Select all shapes in current layer. This is covered early in the docs, in the “Zooming, Panning, Selection” topic that’s part of the beginner path.
