Cuts/layers speed in MM and not In
Has the speed in the cuts/layers always been in MM/Min? i can remember some of my settings for previous jobs and they are more aligned with IN/min. i have my settings set for Inches mm/min in the units/ grid tab in settings. i am aware of the toggle on the page, but that doesn’t seem to change anything on the cuts/layers tab. Using ver 1.7.06
The speed settings are mm/min, which puts the work grid and the speeds in mm, inches/min, which puts the work area and speeds to inches/min, and inches / mm/min, which puts the work grid in inches and speeds to mm. You can set it to any of them, you just need to know which you’re working in.
The same settings apply for C02 machines, except they are faster and typically operate in X/sec rather than x/min.
It is recommended to set to mm/min as that is what the majority of diode users use and it helps with consistency when discussing. Nevertheless, always include the units you’re working in when asking for help, whether inches or mm.
