Cuts out of bounds?
Hi folks, I’m getting a message on the console, saying “G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right click the Devices button to reset the connection)
I do the right click and it seems to be rehoming and restored the connection.
Just can’t get the laser to frame and when I click to start, it’s saying “Cut might be out of bounds “
I’d appreciate any advice?
Most likely, you’re having trouble with the job origin:
Because the machine is homing correctly, using Start from: Absolute Cooordinates will make the LightBurn workspace match the physical machine platform and dramatically simplify your life.
With that set up, use the Preview window to verify that the overscan on both sides of the engraving remains within the machine boundaries:
Cheers , think thats sorted it going to absolute.
