Cutting 2mm cork 5w diode
I’ve seen some other posts about cutting through cork, but not had any luck in finding the answer I need.
Using an Emblaser Core 5w machine. Seeing if anyone has tried cutting through 2mm cork. I’ve designed and cut through some leather coaster and would like to use the cork as a backing to provide some stability.
If anyone has had success, what settings did you use?
Thanks
