I just got my laser and installed lightburn. I tried this two ways…
- I imported a file and placed it in a spot inside the 15.75x23 " rectangle, and used the button to move the laser to make sure it was in the cut area. Mine says Mode lines… Anyways pressed play and it cut a line… Not what I asked …
So fiddled around saw on the controller an error slop
Fiddled more and finally got it to cut a circle after shrinking it down way less than what I wanted … Again Not where I wanted it either.
- Drew a circle did the same thing cut in the same space! Even after moving it to a different location.
So , just looking for advice if anyone’s done this
I am asking if anyone has faced the problem where
The laser bed and the lightburn cutting bed on the screen line up.
How I can fix this so that what I imported or create in lightburn matches what the laser cuts and where it cuts on the machine
I’m asking Why if my laser is a 6040 I cannot cut a 14" circle? Reverting back to #1. Where it does not align
