It looks like those last two line layers are heavily shifted down. BUT, layer 2 is not. So this really places doubt on it being an issue caused by skipped steps or the like due to over acceleration in the fill layer.
I got about a 100 done before today on time it worked another it doesnāt Iām wondering if the file is corrupt some how. Couple times went back to original art work cut two sheets then it would start this crap again
well thatās your file hum I gotta get this order out Iām going to off set the art fro the square ( lie to the machine see if I can fix it some way) itās weird till today it at least worked some times
Thereās a way you can probably make this work that wonāt fix the problem, but will get you through the job:
Group a single keychain, THEN do the grid, so each item in the grid is a group
Go through all the fill layers and set them to Fill groups together, instead of āFill all shapes at onceā
Click the āOptimization Settingsā button in the laser window, and click āOrder by groupā twice, so itās the FIRST thing in the list. That will complete each grouped item before moving on to the next.
Thank you very much the grouping in the manor you said fixed everything ! Light burn people are always helpful and so are the other members here to jump in.
