dumaine
(dumaine)
December 11, 2024, 5:22pm
1
hello,
i have a laser machine with Diodes Atezr,
The cutting does not respect the right angle, there is a small gap.
is it possible to correct this gap in lightburn, as one can do to correct the cutting line lengths on the x and y axes?
thank you
parsec
(FerAS)
December 11, 2024, 5:27pm
2
Are you talking about this behavior:
If so run the file in the following post
Given one picture and four words, I think @JimNM has nailed it.
This test pattern helps identify mechanical problems:
GrundTest.lbrn2
Scale it to fit the platform and run it as fast as it will go in Line mode with optimizations turned off and power set to mark a sheet of cardboard. Any differences from the design will be informative.
Upload good photos of the result so we can look over your shoulder.
then post here the output.
system
(system)
Closed
January 10, 2025, 5:28pm
3
