i am drawing and object in top left area of 300x x 180y mm , when i ask light burn to frame it frames in front left area?? what am i missing here?
Where do you have the machine origin set in LightBurn? This is visually indicated with a small red square.
This is good to review and has a section specifically for your setup. https://github.com/LightBurnSoftware/Documentation/blob/master/CommonGrblSetups.md#common-grbl-setups
lower left ,
my guess is grbl y axis is reversed?
Try changing the LightBurn origin to top-left. If that works with your setup, keep it.
