Cutting off on the left side
Continuing the discussion from Offset Shapes Is cutting out to the left and down:
This looks like you do not have all the shapes centred but i don´t believe that´s the problem… :thinking: :thinking:
Try to check if the dimensions are absolutely correct. You may have to adjust some settings. :thinking: :thinking:
Iam new to this.
What settings are you thinking about.
Thank you very much.
Pat
Before changing any setting, it’s a good idea to see if the measurements (between the screen and the engraving/cut) match or not.
There is a few settings you may need to adjust but there is a procedure to do it. So, check it before changing anything. :wink:
