# Cutting Photo Mount Card
**URL:** <https://forum.lightburnsoftware.com/t/cutting-photo-mount-card/137416>\
**Created:** [April 27, 2024, 11:08am UTC](https://forum.lightburnsoftware.com/t/cutting-photo-mount-card/137416 "2024-04-27T11:08:18Z")\
**Showing post:** 2
**Author:** ![parsec](https://forum.lightburnsoftware.com/user_avatar/forum.lightburnsoftware.com/parsec/32/118933_2.png) [@parsec](https://forum.lightburnsoftware.com/u/parsec)\
**Post date:** [April 27, 2024, 11:46am UTC](https://forum.lightburnsoftware.com/t/cutting-photo-mount-card/137416/2 "2024-04-27T11:46:59Z")
Welcome.
Maybe this [post](https://forum.lightburnsoftware.com/t/stl-slicing-workflow-help/134459/9) will helps for the 3D layers.
For cut settings you have to make material cut tests, depending on the color, but don’t give it too much power and too little speed due to the risk of fire, only change one variable at a time.
e.g. start with 6000mm/m 12.5% power 2mm card, do 4 or 5 multiple passes. increase power 2,5% at a time, and check results.
As a start [here](https://store.creality.com/blog/falcon2-laser-engraving-cutting-parameter-settings) you have Creality settings and you can use 20W mode (less power but smaller beam).
_[View the full topic](https://forum.lightburnsoftware.com/t/cutting-photo-mount-card/137416)._
