Hello I set the flag to cut the internal areas first, but it cuts them at the end and if the cut piece moves, they can come out of place
Make sure the inner shapes are set to the same layer as the outer shapes. If you want them set to a different layer, you’ll need to change the cut order in a different way- you can order by Priority and set the inner layers to a higher priority than the outer layers, or you can order by Layer and move the inner shapes’ layer up in the Cuts/Layers list.
If you’re still having difficulty, please share your project file here so I can take a closer look (or send it to support@lightburnsoftware.com if you’d rather not share it publicly).
