# Cutting transparent acrylic, passes and power
**URL:** <https://forum.lightburnsoftware.com/t/cutting-transparent-acrylic-passes-and-power/12728>\
**Category:** Getting Started With LightBurn\
**Created:** [March 2, 2020, 1:48am UTC](https://forum.lightburnsoftware.com/t/cutting-transparent-acrylic-passes-and-power/12728 "2020-03-02T01:48:48Z")\
**Showing post:** 6
**Author:** ![NewbDudey](https://forum.lightburnsoftware.com/letter_avatar_proxy/v4/letter/n/f1d935/32.png) [@NewbDudey](https://forum.lightburnsoftware.com/u/NewbDudey)\
**Post date:** [March 2, 2020, 3:03pm UTC](https://forum.lightburnsoftware.com/t/cutting-transparent-acrylic-passes-and-power/12728/6 "2020-03-02T15:03:53Z")
Thanks for replying guys!
> [@adammhaile](#):
> 9 passes? at what power? A 50W laser should cut through 2mm acrylic like butter in one pass. I run my 80W through 3mm acrylic at 80% power, 25mm/s.
I figured I was messing up somewhere as the youtube videos showed the K40s doing a better job than what I was getting… I’ll post pics of my settings in a bit.
> [@adammhaile](#):
> This generally only matters for engraving. I almost always leave min and max the same when I want to cut.
I think this is where I screwed up…
> [@adammhaile](#):
> If the protective coating is plastic, absolutely remove it. It will just melt onto the acrylic and you’ll have a hell of a time removing it later.
Makes sense, and thanks for the link 😉
> [@joel1](#):
> 9 passes does seem wrong. With my 80W tube I’m cutting 6mm acrylic at 20mm/S and 50% power.
Yep, feels like I’m screwing up somewhere. Is that one pass?
> [@DanoInTx](#):
> Do you have a mA meter on your machine?
Not that I know of, this is my machine:
[/t/connecting-to-ruida/12255](https://forum.lightburnsoftware.com/t/connecting-to-ruida/12255)
I bought it **after** I was advised that these ruida controllers are most compatible with LB…
> [@Bonjour](#):
> I prefer one cut, with air assist.
I have air assist on this…
> [@Bonjour](#):
> You should be able to cut 5mm in one pass.
That’s what I wanted to hear as thats the main purpose of this buy; 5-6mm cuts!
> [@Bonjour](#):
> Having min/max allows it to drop the power as the head slows over the material during cornering.
Going to have to play with these settings a bit…
_[View the full topic](https://forum.lightburnsoftware.com/t/cutting-transparent-acrylic-passes-and-power/12728)._
