Cutting traverse lines even after putting in $32=1, origin and home are both top left, no clue what else to do?
Using a falcon 2 22 watt laser from creality. Total noob totally lost!!! Plz help!!
In the Laser window, look at the bottom right text box. Now click on the Devices button. What does it say for GRBL type for your laser?
GRBL-lpc gcode
Did some searching and pound this in a posting. Try just plain GRBL and see if that helps.
Not all 32-bit boards but a very specific 32-bit board with controllers made by NXP. I’ve not actually seen anyone in this forum actually using an LPC board running GRBL. These typically will run Smoothieware.
@PMJ2376, you definitely want to be running “GRBL” and not any other variant. GRBL is typically the most current and has the most latest updates.
So what do I need to change?
Click devices in laser window then click create manually.
