Physics. If you cut or carve little 5mm squares on your material, the results will match. The laser is not able to get up to full speed to spread out the energy. If you make 50mm squares, you will see a better match in the results.
The Material Test is a guide, not a solution. It is adjustable, so it is up to you to set it up for your application.
