Dazed and Confused
OK I have completely lost it…I am running LB 1.4.03 to a xTool D1 Pro. I draw in LB a 1 inch square. Then I burn it. So far so good. Than I move the square 1 inch in the X and Y axes. I attempt to burn again but the square shows up in the same spot on the wood. WTF is going on? Please enlighten me. Thanks.
Probably in this area.
As Mike pointed out, this is usually desired depending on your settings. Check out this:
