De offset fill gebruiken
Good day
when I use the offset fill option the letters are engraved criss-cross and not straight on the line
is this normal or do i need to change more in the settings
Greetings Ronald
Offset fill should create loops inside the letters.
If the Font is designed in several blocks strange behavior could occur.
Would you be willing to share the LightBurn File? It is hard to see what you’re seeing.
You may find that Bidirectional Fill is faster, depending on how many letters you are filling.
Hi John
thanks for the reply
if i set c26 to file it takes 9 hours and if i set it to offset fill 5 hours but i have the problem
Greetings Ronald
Failed to add file
zijkant container.lbrn2 (161.3 KB)
it worked anyway
