Is it possible to set your default cut and engrave settings to what you use most?
LightBurn doesn’t really have “defaults” - All color layer settings are remembered between runs, so whatever you set them to becomes your new defaults. You can also use these buttons:
The top one takes the currently selected cut setting and copies it into a ‘stash’. The bottom button applies the stashed entry to your currently selected layer, and the stash is remembered between runs as well. If you set it once, you can use it to quickly apply your preferred default settings to any layer at any time. There is one stored for images, and one for cuts.
Awesome, great to know. Thank you!
