The first time I opened a photo in Lightburn for engraving, there were default engrave settings. I think they were 100 speed / 20 power (max). I’ve been playing around with engraving photos and now when I import a photo, I can’t get the default image settings back. I’m trying to recall if the minimum power setting was the same as the max setting or if it was zero
For any of the dithering modes they should both be the same.
The only time you’d set them different when doing an image is if you were using grayscale. On a CO2 laser that will usually give you varying depth, not variable shading though.
In the cut settings editor window there’s a button at the bottom left to reset to default.
Thanks Oz
If one wants to edit all minPower settings throughout its library to match that of the maxPower - what are his/her options other then edit the xml/clb and manually change all settings one by one?
thx.
Here is the complete list of other ways to do it:
Damn, i hate multiple choices.
