Today trying to cut a box I have observed that the vectors come out jagged, that is, as if they were saws and the design sent is clean, with few nodes and well defined as you can see in the attached LightBurn capture.
… are you sure it’s not polypropylene or polyethylene ?, if you do a test in plywood or wood, the lines are just as uneven? (is it the laser that runs so strangely or is it the material that deforms when cut?)
I’ve checked mirrors (I see them a little dirty but I’m still not sure how to clean them without damaging them, sorry), I’ve tightened a couple of nuts (just in case) and I haven’t seen anything that moves.
I do not know what is “carriage loose on gantry” forgive my ignorance, I learn every day, after watching many videos and reading many threads in this forum, thanks.
The gantry would be the long rail that moves in the Y direction (highlighted in green) and the carriage is the part that moves along the gantry in the X direction and has the laser head and lens attached (in blue)
I had a similar issue a while back, for me, it was a loose mirror. It was one of the first things I checked and thought all were good. Went back another day and found one.
It takes very little movement to do that. I put on latex gloves so I could touch the mirrors and try to wiggle them. My holders have a hole on the back side, so made pinching the mirrors and try to wiggle them easier.
I bought a lens cleaning kit and I will take advantage of a video where it explains very well the cleaning and calibration https://youtu.be/T9p-1AZKCVg and I will perform the process to see if the lenses return to their previous state.
