Deleting Nodes from a Boxes.PY file
I am using Boxes.py and trying to delete nodes as I want ONE line from the box to be a straight line. I use CTRL D after selecting a node and nothing happens. Is it not possible to delete nodes of the box sides?
Thanks in advance.
As far as I know you can only manipulate ‘nodes’ via the node editor…
In the node editor that is just ‘d’ no control sequence. If you hover over the node edit icon it will show you the commands.
You can also delete multiple nodes at once by selecting them (either with shift or window select) then hitting ‘d’.
If you hover over the node and then hit the “d” key it deletes as does a line…
I was hitting CTRL D together. With just the D key it worked! Much appreciated so thank you all for the help.
