Need some quick help… I’m trying to delete the lines at the end to make an open area for a split monogram. I had to weld the image and box to remove the middle but now I’m stuck with a rectangular box. I would like it open. Is there a way to do this?
What do you want to remove?
The rectangular are has vertical lines at both ends, is this what you wish to remove?
Might drop the .lbrn2 file on the reply window, it will upload and we can look at it…
Maybe you can be a little more clear of what you are trying to do…
I think you want to remove the ends off the ‘rectangle’…?
I would use the node editor…
