Design changes when different laser selected in LB
When I design a project at my desktop, I have a fake Xtool D1 “connected” to generally match mine out in the garage.
When I open the file out in the garage and swap over top my Atomstack X40 Max, all sorts of things change. It’s not just a straight mirroring, but items within a design go haywire. This happens even if I “Lock” the design. It’s most troublesome when I’ve applied a path (like a circle) to text, as it won’t let me just mirror flip the text.
I’d appreciate a kick in the right direction to fix this, as I’m ready for production on a couple of items until I get out to the laser and open the file to burn it!
I’m wondering if I should create a fake Atomstack X40 and make sure I choose that when designing items for that laser.
Kind regards,
Marc
The machine profiles include a lot of settings - some of which are based on origin.
Would be idea that you used a “dummy” AtomStack on your design computer if you are going to run on it afterwards.
Correcting for wrong machine is possible but a extends the work flow in a way that shouldnt be necessary.
You can make them match exactly, which will eliminate a whole bunch of jank:
Hrmph. I hadn’t thought about that idea, as this is the only goofball issue I’ve hit.
Everybody should be so lucky!
I gave this a shot, and I’ve had excellent results. “Cloning” the installation on my production computer to my design computer was easier that I’d expected, and seems to have made the difference.
Many thanks!
