I have red 100W CO2 Chinese laser and use lightburn software. I worked with the tech support on the laser and find that it is not the laser that has the problem. When I save the design in lightbrn format and send it to the laser it does not engrave lines as the pattern shows but when I used the Save RD file and clicked on Run RD file it does a beautiful job and everything is lined up. I am wondering if I have something set incorrectly in my lightburn software? I also saved the design as a dxf format and sent it to my Jamieson lg640 CO2 laser 60W and it worked perfectly.
The attached image 1 shows it perfect in RD file the second image shows the mess in the lettering and cutting using lightburn.
