Desperately need help with Ruida 644XG travel limits & axis calibration (LightBurn 32-bit issue?)
Hi everyone, I’m hoping someone here can help me save my sanity. I’m running an OMTech 24x40 (Ruida 644XG controller) using LightBurn 1.5.06 on an older Windows 7 32-bit system. (I know, I know, but it’s what I have to work with right now!)
I am having a terrible time trying to get the machine to communicate the correct physical dimensions. I’ve been going back and forth with support, but we are stuck in a loop. Here are the three main issues:
1. The Bed Travel Issue
The machine will not travel the full 24x40 bed. It stops early and claims it has reached the end of the axis. In the Machine Settings, the “Max Travel” limits got swapped (X was set to 1016mm and Y was set to 609mm). I manually set them back to X=609.6mm and Y=1016.0mm, but it still acts confused and wants to stop way before the physical end of the bed.
2. The Axis Calibration Issue
The scaling is completely wrong. I am trying to cut a simple 100mm x 100mm square. My “Step Length” values are currently a mess because I’ve been chasing my tail trying to fix this.
  • Originally, the X step length was 5.94183 and Y was 7.61764.
  • When I command a 100mm square, the machine cuts a rectangle that is roughly 5.5 x 6.5 inches (or worse, depending on what step length I try).
  • I tried using the “Calibrate Axis” tool in LightBurn, but it is incredibly buggy on my 32-bit system. Every time I input the actual measured distance, it resets to “No Current Calibration Changes” and doesn’t save the math. I’ve resorted to doing manual math to adjust the Step Length (um), but I can’t seem to land on the right numbers.
3. The “Squeezed” Look
Depending on the step lengths I try, the resulting square doesn’t just come out too big or too small—it comes out “squeezed.” It is clearly moving the X and Y axes at different proportions. It’s never a true square; it’s always stretched into a tall or wide rectangle, which tells me the X/Y scaling is badly mismatched.
What I’ve tried:
  • Manual step length calculations (I’ve gone from 5.94 down to 1.24 on X and 7.62 down to 1.87 on Y, and it still isn’t hitting 100mm).
  • Verified the belts are tight and the pulley set screws are secured to the motor shafts (they seem okay, but at this point, I’m doubting everything).
  • Checked to ensure Rotary Mode is OFF.
My questions for the group:
  1. Is this a known bug with LightBurn 1.5.06 on 32-bit Windows 7? Is it corrupting the controller’s Step Length writes?
  2. What are the factory default Step Length values for the OMTech 24x40 (Ruida 644XG)? I want to reset them to baseline and start over.
  3. Is there a better way to manually calibrate this without using the buggy LightBurn calibration wizard?
I am pulling my hair out trying to get a simple 100mm square to cut as a 100mm square. Any help would be massively appreciated!
I won’t say much because I’ve seen somewhere that the Ruida system has its quirks.
What I suggest, because I admit that whoever can really help needs it, is a screenshot of the settings. Both from Lightburn and the Ruida system.
I think, as you described, you need to get to the bottom of your step length configuration before you can get your travel distances to be accurate.
Omtech should be able to provide these values, or you can find the stepper drivers and determine their microstep settings from the DIP switches, then combine that with the steps/rev of the steppers and the gear ratio of the belts.
This should help with that calculation: https://makerhardware.net/steps-per-mm-calibration-calculator/
Likely due to having Rotary Mode inadvertently enabled. Make sure that’s disabled before fixing the axis calibrations.
Thank you for that. It is indeed not active.
