Where it says ‘Auto’, you might have to choose a COM port - sometimes this is enough. If no port is showing in that list then you may need to install drivers, or might have an issue with the board itself, like the firmware isn’t flashed on the SD card, or the SD card isn’t inserted - either of these things will prevent the board from being recognized by the computer.
Thanks for coming back to me. It doesn’t give me a port to choose. I’ve bought the machine and the software as second hand and I am not clued up on what is supposed to be on the SD card. The SD card came still inside the machine, can you please tell me what firmware should be on there and then if I need to download a driver can you assist me on what driver should be the correct one? I am using windows 8. Cohesion 3D Mini board.
For Windows 8 you don’t need a driver. There is a MicroSD card that should have come with the Cohesion3D board that contains the firmware that runs the board.
Those are the files to put on the SD card installed in the board. When you plug in the board you should hear Windows make the telltale ‘Bing!’ that means it recognized a new USB device.
