Device import for XTool D1 Pro - every time I startup
Hey friends, I’m new here, so hopefully I’m putting this question in the right place. Every time I disconnect my laser, turn off my computer, or close down Lightburn, I have to re-import the D1 Pro as a device before Lightburn will recognize it. The bummer here is that I then have to recalibrate the laser offset and any other presets I have for the device. Of course, I forget to do that and then end up trying to cut something that runs off the material. Has anyone else run into this issue? I’m running on a MacBook M1 Pro. Thanks!
Is it present from the previous setup or is there nothing.
Might want to ensure you have permission to write on the machine…
It should only have to be done once…
