Did nodes change I cant seen to delete the line between two nodes ?
How are you going about doing this? Are you in edit node mode, hovering the mouse pointer over the line, and hitting ‘d’ on the keyboard?
yes thats what i was doing
Control D and Shfit D and Deleat
Not following. You shouldn’t need to use any modifier keys. Just press the letter ‘d’ (with no quotation marks) while hovering over the line.
I just tried this and it seems to work the same was as I remember.
What version of LightBurn are you on?
Ok I got it to do it with just the d its been a while and I thought I used to have to Press Shift I to add a node and shift D to remove things. Thanks for helping
