I’m trying to cut laminates. I’m wanting to set the initial pass to 100% to cut through the while layer on top then the additional passes at a lesser power. I was told that was running too hot leaving a sticky residue but any less power wouldn’t penetrate the first layer. I have tried cutting with black side up but wasn’t as clean. Is there any way to set multiple layers per cut?
Use multiple layers, centred on each other so there’s no variance in the path. Each layer with it’s own power/speed setting.
