Testdatei Eigenbau wechselnde Leistung - schneiden Test 3.lbrn2 (92,2 KB)
Testdatei Eigenbau wechselnde Leistung - schneiden Test 6.gc (50,2 KB)
constant Power Mode doesn`t work either
Testdatei Eigenbau wechselnde Leistung - schneiden Test 7.gc (49,9 KB)
Testdatei Eigenbau wechselnde Leistung - schneiden Test 4.lbrn2 (91,0 KB)
Powerscale is part of form settings
its pretty simple if you got the right tips to find it. Now it should work I think. Thanks a lot for your support
Testdatei Eigenbau wechselnde Leistung - schneiden 8.gc (50,0 KB)
Testdatei Eigenbau wechselnde Leistung - schneiden.lbrn2 (91,0 KB)
This is the final file with 100% power and diferent speeds.
Ok, so now we’ve taken the power scale settings out of the equation as your rectangles are all now set to 100% power scale and the only thing to affect the cutting performance is the layer power and speed settings.
In your original posting you said:
If all you want to do is satisfy yourself that the layer doesn’t make any difference you’ll need to set all of the layers to the same speed and power.
I would highly recommend reading the LightBurn documentation to get a good grasp of the software.
As @jkwilborn mentioned: this is what the Materials test was created for.
In the beginning it was a test for cutting in diferent material, but it didn´t work like it should. So I did the same settings to all layers and again not the same results. I never did a manualy change to the power scale and so I clouldn´t explain why all happend like it did. To me one setting for power and speed per layer is enough. I will not use power scale - keep it simple.
Thanks for your support.
