Two versions/instances can be open at the same time, unfortunately the two can’t talk independently. The first LB opened is the “master”. When you close that one, the second instance can start talking to the second laser.
That’s only true if they’re trying to talk to the same laser, which isn’t the case here. Each instance can maintain a connection to a different machine with no problem.
C3D does not buffer the job - it’s streamed, so if you started a Ruida job then streamed a C3D job it would be fine from a single instance. Once the C3D job is started you couldn’t switch to the Ruida until it was done streaming, so a 2nd instance of the software would be more flexible.
So to confirm I am understanding this right before I proceed with the cohesion purchase. Lightburn can communicate to each laser at the same time?
If I am using 1 instance of lightburn then I need to wait for c3d to finish before I can restart the ruida job. But if I just open another instance of lightburn then I would not need to wait for c3d to finish before starting ruida job?
Seems there is mixed answers.
-Grumpy_Old_Man saying it cant communicate with more than one at the same time.
-Patric confirming this and also saying he has 2 lasers and not able to communicate at the same time
-Oz saying you can communicate at the same time as long as 2 instances of lightburn are open.
-Also Oz on another thread here Multiple lasers - 1 computer working at same time - possible? (last post) says it can only communicate with one machine at the same time even though 2 instances are open
Thanks for the quick answers so far, hope to get a definitive answer.
Putting a Ruida on a K40 is like dropping a V12 into a Yugo.
There are better, cheaper solutions - let alone the problem of fitting it in the case, with drivers, etc. (you do realise you have to buy external drivers as well?)
Much better to a) buy a better machine with a DSP controller in the first place or b) use a decent controller with built-in drivers (or plug-fit SMD drivers) and ethernet.
The cost of a RuiDa controller is about the same cost as the K40, before you purchase drivers, etc.
Patric was wrong, as evidenced by Oz’s correction.
You misread Oz’s post in the other thread - he made two independent statements:
“It’s also possible to run multiple instances of LightBurn on the same computer, with each instance connected to a different laser.” - so, two instances, talking to two different controllers concurrently.
And:
“LightBurn will only actively communicate with one machine at a time, but with DSP controllers that buffer the whole job (Ruida, Trocen) you can send to one, then connect to the other laser and send a different file.” - in that paragraph he was talking about running a single instance, and connecting to two DSP controllers, consecutively.
For us Unix and Mac OS users, it’s a lot easier to replace the awful M2 Nano controller with something more useful, and that supports PWM power control.
One instance of LightBurn can communicate with a single laser at one time, and maintains an active connection, so a second instance of LightBurn cannot communicate with the same laser as the first instance. A number of users will run a 2nd copy of LightBurn to prep a design while the first instance is running, then try to send a job to the same laser from the second instance. This doesn’t work.
Anthony (Grumpy) says you can’t communicate with more than one laser at the same time. This is correct. With a Ruida system, you can send a job to be cut and the machine buffers it while it’s running. Once the send is complete, you can pick a different laser and send a job to that one. If the laser you’re talking to requires streaming the job (like most GCode controllers) the connection has to be kept until the job is complete.
There is no issue communicating with multiple lasers using multiple instances of LightBurn, each communicating with a different laser, either via USB or Ethernet. On a Mac this is troublesome because MacOS itself prevents multiple instances of the same application from running, but that’s an OS issue, not a LightBurn issue.
You’re welcome - I hope the answer didn’t come across as hostile or anything. It wasn’t intended to be, I just wanted to make sure it was very clear what the limitations were.
I know why you’re having trouble: Ruida controllers, if I remember right, use a fixed incoming data port on the PC, so when trying to create the port for the incoming responses from the controller for the second instance, it can’t. If you were USB connected with one or both of them, that would work.
