New to lightburn and this forum. I have ortur lasermaster 2. Can you use different scan angles for a second or third pass. Can the angle be alternated? Thanks
I’ve never actually done it but I don’t see why this wouldn’t be possible with the new sublayers capability. Setup a different sublayer for each angle that you want and in the order that you want.
Unless I’m missing something you can’t change the scan angle on a second sub-layer. It’s also not available at all on the 00 layer.
Maybe I’m interpreting the ask differently but I don’t see a problem with it. Check out the example.
Sub-layer 1 @ 0 degrees:
Sub-layer 2 @ 20 degrees:
Sub-layer 3 @ 40 degrees:
I’m an idiot!! Scan angle doesn’t show up with line!!
