Dimensions are not real
I’m not able to solve this problem of dimensions, as the result of cut is different from real size.IMG_20211022_121206|375x500
Calibration of cutter?
You need to ensure that the software knows how many steps = 10mm of movement etc. Check this first.
Sei italiano? Se si e non sai come calibrare gli assi contattami in privato che te lo spiego.
Sounds like you have not run the calibration and skew test. Until you do, none of your measurements will be correct, and your shapes will be off.
