Diode laser won't seem to engrave below 5000mm/min above 40% power
Hi I wonder if anyone can offer any advice or suggestions please. Very novice at this! I have a Chinese diode laser. I usually use it for imaging but have started to try to use for some font/cutting. On speed settings such as 6000mm/min with 100% power the laser fires and moves round in a continuous motion. However much speed below that, it frames as normal, but goes to the start point and simply fires a few dots and won’t follow the shape. When I use 40% power it seems to move fine at lower speeds. I’m using GRBL1.1. and my settings are below. Could anyone suggest anything please. I’ve tried searching the forum and a few other things but a bit stuck as alot of the speed related issues seem to be with higher speed not getting lower speed to work. Thank you!
$0=10
$1=25
$2=0
$3=2
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=1
$100=80.000
$101=80.000
$102=250.000
$110=2000.000
$111=2000.000
$112=2000.000
$120=10000.000
$121=4000.000
$122=10.000
$130=200.000
$131=200.000
$132=200.000
The $110 and $111 values limit the top speed to 2000 mm/min along the X and Y axes, so the top speed cannot exceed 2800 mm/min (*) regardless of the commanded value.
The configuration looks like it’s intended for leadscrews, rather than a belt-drive machine. If it’s a leadscrew machine, higher speeds may be beyond its capabilities. If it does use belts, then the configuration values need tuning for typical laser use.
Some useful guidelines:
This suggests the power supply cannot supply enough current for both the laser diode and the stepper motors. As a rule of thumb, add up the total current for stepper motors (typically 2 A each), the input current for the laser head, and about 1 A for all the other widgetry. Double that number and make sure your supply has at least that current rating; typically, it does not.
(*) That’s along a line at 45° from the axes, with each axis running flat out at 2000 mm/min.
Thank you so much - I will look at the configuration in much more detail. However the second point as I think you suspected is the issue - I had managed to use the wrong power supply for the last few days…
Keeping them straight seems to be a problem. Long ago, I began labeling which supply goes with which gadget, which definitely helps. Now I have a big box of supplies from obsolete junk that “might come in handy some day”. :grin:
Full power ahead!
I label my by output - Wattage, Volts and Amps, then match those and find one with correct size plug, I have about 35 to sort through otherwise.
Aaaaand whether the output is AC or DC!
Nearly all supplies produce DC these days, but quarantining my AC supplies in a distinctly separate bag prevents a great deal of heartache & confusion.
Do not ask how I learned that lesson.
:face_with_open_eyes_and_hand_over_mouth:
I won’t ask but can imagine letting some magic smoke out, my 2 AC live in a different room for that reason as there is only 2 so no need to label.
