Is there a setting in Lightburn that can be set so that paths during a multi pass cut is in the same direction ?
I have a job that requires two passes and when lightburn generates the path it does it in an out and back direction.
I would prefer the passes to be in the same direction.
Another item that I am trying to figure out is that for some reason, lightburn breaks up the path into multiple cuts rather then making the cut in one complete path.
The DXF file when imported into lightburn it is one complete and joined vector and not multiple vectors.
