Disabling the fire protection
I’m trying to disable my fire protection system. Can I get some help. I’m using a Ray5 10w machine.
Type $261=0.
My system says command not recognized
Are you typing the correct characters?
Yes and it says command not recognized.
Doesn’t it have to be $[setting]=[value]. Or $[261]=[0]
Nope that doesn’t work either.
I’ve got this on the side of my machine
That´s the emergency button.
Are you connecting trough USB and WIFI?
Did you setup your machine as plain GRBL?
I’m using USB. I downloaded the software and been using it for over a year. Just a newer machine
Enter $$ in the Console window and see what you get. Your controller may not allow changing (maybe some) GRBL parameters. This test is to see if it will list them.
How do you work over WI-FI. My computer and machine are both connected, but I’ve always used USB
