Hi, how can i distribute n small rectangles/points evenly on a circle?
Thanks & Regards
Thanks & Regards
The Radial Array (or circular array) tool lets you create copies of a shape (or shapes) around a central point. This is useful for creating ornamental patterns, clock faces, and more.
You can manually enter the point of rotation, but it’s much simpler to create a shape to use as the center point, and select that shape last. The created copies can be rotated or not - Numbers on a clock, for example, are often left upright for readability, but roman numerals are usually rotated.
In the above example, the small center circle was selected last, and the ‘Use last selected object position as center’ option is chosen, along with ‘Rotate object copies’ to produce the pattern.
Works perfect !!!
Thanks you for the feedback and support
