If anybody else is looking for information on precision UV lasers, I’ll leave this here just in case. This is what I’ve learned from speaking to people in the know. Though I still don’t know enough. Please do correct if wrong on any point. One reason I’m writing this out is to learn/remember myself.
ps. I’m talking about ‘UV’ lasers, but actually 343,355,515, or 1030NM matters far less than I initially imagined.
Safety first: Reaching out to the various people I know in academia and industry, one thing has become clear. This isn’t a DIY job on the source side. Multiple professors and grad students blind themselves and each other doing this sort of research.
The hobby class claims of near micron accuracy are horsecrap. By a factor of 50x or so. 2 major sets of factors play into small diameter cutting and marking, and these are as follows:
Spot Size
This is defined by a few factors:
Beam Quality [at source] measured in M² : Anything over 1.2 will not get tight spots, and it gets progressively less tight (multimodes fibers have a 0.3mm or so spot size!)
Galvo scanner quality: A galvo scanner can achieve a 5𝜇m spot of even lower, but this is a damned good one [read research quality] - 10𝜇m with a beam quality of 1.1 and good quality optics is achievable ‘normally’ and this is the kind of limit.
Optical focus and quality: F-Theta lenses do have inherent limitations as above. A short focus lens with excellent optics is essential. Because the focus range is sub 0.5mm, you’re also required to devise a way to non destructively probe your object at the ablation points if it’s 3D (Like in my case) to ensure focus.
Minimum hole/mark Diameter/quality
Spot size directly translates to 'hole size, but as the laser works by ablating material with energy - the longer you fire energy into the material, the type of material, and the intensity of the pulse all matter.
Pulse duration (NS = Nanosecond, PS = Picosecond, FS = Femtosecond) - In the standard NS setup, you’ll typically fire a pulse for at least 9ns. This can be reduced to pico or femtoseconds. The speed of the pulse determines the total energy being transferred to the item. A longer (ns) pulse will typically burr and make a conical mark. An FS/PS pulse on the other hand, will transfer far less energy, hence making a smaller colder hole. This is most easily demonstrated by two of the lasers I am considering. A 60W [nd:yag @ 355nm] laser firing for a 20NS duration, will transfer 1000mJ. A 60W [femtofiber @ 1030nm] laser firing at 200FS will transfer under 2nJ.
