Do not cut areas, which have a filling on top
Hi Folks,
for me works well to create the inital drawing in libre impress or power point. I am exporting a pdf and import it into lightburn.
The green areas are supposed to be filled, which is working fine. But I am looking for a setting which helps to NOT cut the yellow marked (red) lines anymore, because the green shape (oval) is on top of these red lines.
I played around with “optimization settings” but it did not help.
Regards
Thomas
You’ll need to remove those lines. Upload the .lbrn file to see if we can help.
