Do not want to cut duplicate lines
As you can see if there was a way to not cut along all those parallel lines twice it would save me a lot of time. I do not see any option to not cut duplicate lines. I do not believe the “Delete Duplicates” function applies, nor does it accomplish what I need. Please help.
Correct, as this requires the shapes to be very close to matching the original. Have you looked to the ‘Optimization Settings’ found in the ‘Laser’ window, to see if that helps? There is a setting there to ‘Remove overlapping lines’.
Wow! I was not aware of that setting. Thank you so much. That seemed to have taken care of the issue.
